SJordan
If you have a straight 4-pipe exhaust with smoke system can you please post up:
Number of injectors
Location of injectors
Flow rate
Quality of smoke.
I have a 4-pipe with 4 injectors about 10? from the tips and my smoke is beyond terrible. Trying to determine if it?s my homegrown injectors, flow rate or to cold of location. I have welded in NPT ports and a coated exhaust so trying to eliminate any additional trial and error here.
Thanks for any help.
I do
I have the 4 pipe Vetterman on my -4, with 2 injectors on the 2 outboard pipes. My smoke is decent, but typical of the single pipe-per-cylinder set-ups, I have a series of puffs...funny to watch in super slow motion video, as it looks like a steam locomotive. Mine are from Smoking planes, and are about 12" from the end. I do get more residue than I like on the belly, and plan to add 2 more injectors on the other pipes. In hind sight, I would have put my injectors up front but I didn't want lines run up that far. Cant tell you the flow rate, but my "valve" is only open about a half turn.
My home made system
Rv4 o320 vetterman 4 pipe
The late Dave Beisemier made me 4 injector nozzles out of stainless bolts. Held in by band clamps same as your egt probe. Dia of nozzles are .100 inch ( .100 is to small and prone to blockage from burn residue. Your an fittings will work fine I used those on my pitts set up
My nozzles are about 4 inches below exhaust port. I used 1/8 inch stainless lines from a homemade flow divider to each pipe. (I would use 3/16 or 1/4 lines if i did it over) also would have moved the injectors to just above the ball/slip joints
4 gallon tank in fwd part of bag comparment wwlded .050 6061 sure flow ag sprayer pump 70 psi. ( bigger lines would allow for a smaller low pressur pump ( facet fuel pump).
No regulator runs through 4 gallons in about 8 mins
Makes great smoke if using good smoke oil. Cheap substitutes give crappy smoke
https://youtu.be/yDux0BHahrw
Cm
Sure seems like 4 into 2 makes better smoke.
I have 4 into 4 system with two Smoking Airplanes fan injectors. Have experimented with injector location. On mine there is no doubt that up closer to the cylinder works better. I moved them back to about a foot from the exhaust end and smoke was noticably weaker. My flow rate through the injectors in 1.7 gpm. I have Edelbrock 72051 solenoids, number 6 lines to the solenoids and number 4 24 in lines to the injectors.
Flying next to planes with identical hoses and injectors the 4 into 2 systems smoke looks better. It has to be the extra flow and temp of 2 pipes compared to 1.
I have a 4 pipe system on my RV-4 and it smokes like crazy. I have even done some skywriting with it. I have smoke oil injectors in all 4 pipes and the injectors are mounted pretty far up the pipe not too far from the cylinders.
I have 1 oil supply line that goes to a manifold block which has 4 outlets.
This entire 4 pipe kit is available on the smoke-system-helper web site.
