FlyingDiver
Page 21is/U-05, Step 10, Figure 5 calls for wheel bearing grease. Can I use white lithium grease instead? This isn't a high temp or fast movement location, it's just the pivot points for the flaperon mixer arm.
Recommend Mobile 1 Synthetic. Very tacky, sticks to rod ends and anything else, extremely well.Page 21is/U-05, Step 10, Figure 5 calls for wheel bearing grease. Can I use white lithium grease instead? This isn't a high temp or fast movement location, it's just the pivot points for the flaperon mixer arm.
