Now this is getting down to details....
We were having a small debate in the hangar last night over the need for a Whistle Slot in the crankcase breather. As we have all been taught, a hole should be placed in the breather tube up above the end, preferably inside the cowling, so that if the end freezes over, we don't overpressurize the crankcase. Good idea!
But what if the end of the breather tube is ALREADY inside the cowling, and moreover, poised just above the exhasut pipe (as many folks have done in an attempt to burn the oil, rather then streak the belly...)? It is highly unlikely that the breather tube could freeze over! Is the hole still necessary, or is it just traditional? And should it be a true "Whistle slot" (A slit across the tube, with one side pushed in), or is a simple drilled hole sufficient?
Inquiring minds want to know! (See what happens when you bring out the beer at sunset?)
Paul Dye
Not responsible for the question, but interested in the answer....
Paul Dye
