jim plaster
Replacing a damaged starter and ring gear on a 180hp o360. Removed the prop and found a couple of rounded nuts on the mounting flange for the prop..Needing to order replacement parts and didn't write down the stud size for ordering the right castle nuts....anyone remember if they're 7/16 or 1/2 " studs?thanks guys!
