hydroguy2
Kinda makes you nervous when you smell fuel with under 5hrs on a new engine/airframe.
I topped of the tanks today to do fuel burn calibrations. I launched from RY16(3890msl), straight out and climbing ~2000fpm 115mph, shallowed the climb to about 1000fpm 145mph. Leveled off at 7500, and as speed increased to 175 it was getting pretty rough. I am still trying to breakin the engine, but no way I'm going to be able to run 24sq. The mostly cloudy skies opened up to the south, so pointed her to the blue.
As I climbed thru 8500' things smoothed out real nice, at 9000' climbing 1000fpm....I smelled fuel, Fairly strong considering I have lots of air coming under my canopy edges. Surprised I'm 15miles south of the airport at 9300' 22.9" 2400rpm I was indicating 175 and 400fpm climb. Quick call to my buddy telling him I'm returning to the field. I make a 180, switch tanks... everything good, smell is gone. But I'm nervous, and touchdown a little hot and balloon up, a tiny bit of rpm and she settles on nicely.
Once on the ramp I shutdown and inspection showed nothing. Pulled the upper cowl and nothing indicated.
My hope is full tanks, bumpy ride and/or climb sloshed some fuel out a vent.
Any ideas or help?
Then after I had a late lunch and thought about things I went back to the airport, went back to check fuel levels. Right tank was down ~2" from full. I only ran this for 10 minutes. No loose fittings, so wonder if I siphoned some out. Unable to find anything, I figured I may as well take her up again to do a sniff test. Run up good, climbing again at roughly 2000fpm and shortly later got a faint whiff of fuel.....level off, nothing.... switch tanks, nothing. zoomed around for 1/2hr, with a couple shallower climbs and nothing noteworthy....except the truly fantastic performance I experienced!
WOW. these little planes are wild.
Any ideas or help?
