I had the same thought before we installed ours. We put ours on the right because we had room on that side of our panel for the vent.Im going to cut the hole for a NACA vent tonight and I need to know which side it should go on. I think I read somewhere that one side wont work. Any advice would be appreciated.
I'm not trying to be a smart ___, but the plane is symmetrical, so why would it matter which side you put it on? Both sides get the same amount of air don't they?
I was planning on prosealing them on (also with old prosealDon't forget to put some screening (hardware cloth) over the opening to keep the bugs out.
I was planning on prosealing them on (also with old proseal) but I hadn't though of the screening.
It's a good idea, but how would you mount it? Trapped in the proseal between the vent and skin? If so, then with my luck it would immediately need replaced and I'd have to try to remove the vent.
I know it would plug up easier, but could the bug screen be put inline on the scat tube side?
You get prop upwash on one side and prop downwash on the other. It makes a difference.
tm
Scott, that isn't steel, it is Ti.Holy cow Bill, with as much as you've talked about building light, you have a steel hose clamp on that NACA vent? !! (Just ribbin' you), A good old zip tie will be plenty, and save a tenth of an ounce or two.. I can't speak too loud, I have a few rivets as well as proseal on my vents.
I used Van's vents and they leak bad. Has anyone replaced them with the ones for Stein.
Yea the entire front top skin comes off on the 3.That may not be an issue with the -3 as I think the entire forward skin comes off, does it not?
It looks like it will indeed interfere with the rudder controls if I try to mount it under the cowl cheek. I need to double check this with the cowl cheek in place. I also found that the vent i bought will only work on the left because the exhaust angles up 90 degrees. Could you post those pics of your setup?Especially if you have a 3 or 4 with cowl cheeks. Before you cut out the hole take into account the rudder pedal and associated linkage as I am sure it will interfere with your vent. I pulled my fresh air off the rear baffle with great success. If interested send me an email and I will explain with pictures.
Rv3 pilot
