Desert Rat
I know that the preferred way to do this is to use the firewall mounted oil cooler kit. I though that I had ordered the correct part number but I was clearly mistaken because what Van's sent me was the oil cooler kit for the baffle mount.
Can somebody who's gone this route help me understand what part numbers I need in order to get he right stuff? I already have the oil cooler, I just need the sheet metal box, scat tube, & lines. (For the lines I'm not adverse to having them made by TS flight lines if there's nothing off the shelf from Vans).
Firewall oil cooler
I'm not home but I used the RV10 parts on my 7A IO360M1B.
I can provide a list with part numbers later.
Oil cooler
Mount
Also bought a 4" flange and butterfly vlave, 4" scat and a control cable.
Mounted on the Port side of the firewal.
