werxcv01
RV-8, O-360, fixed pitch Sensenich prop. Current setup is one CMI magneto Model S4LSC-21 running the lower Tempest REM40E plugs and one E-Mag Model P113 (a P-Mag) running the top NKG BR8ES R solid post plugs.
What should I consider if I want the most reliable setup?
Two of the same type, I would replace the mag with another P-mag.
But, there is no real answer to this question. You will find people who have had trouble with each type of ignition system. My view is a self powered ignition is intrinsically more reliable than one dependant on an external power source, which is any ignition other than a mag or a P-mag. But that's only my view.
I'm about to replace 2 mags with 2 P-mags.
Pete
My thoughts:
- Your 113 series eMag is at least a couple of decades old. If you keep it you need to send it in to update the firmware. Better choice however is to install two new pMags now.
- I hate mags. I hate aviation plugs and the maintenance they need.
- I installed pMags on my old RV-8A, on the new RV-8 as well as my old RV-10. The IO-540 engine I just ordered from Thunderbolt (Lycoming) will have dual pMags.
I suggest there are two basic ignition camps:
- The ignition does not require ship power to keep the engine running (traditional mags or pMags).
- The ignition does require ship power to keep the engine running (all other EI options).
If you go the second route, you will need to do a careful design of your power distribution system. I suggest just adding a small backup battery is not sufficient.
Carl
Thanks for the replies. I had been thinking about replacing the aviation mag with a second P-Mag, but my P-Mag has been sent back for a second rebuild in 3 months, and the aviation mag was checked and found to have problems within 250 hours of a 500 hour inspection. I believe once the shop returns the airplane to service, I will monitor both mags closely for a while and research more before deciding which to replace.
The backstory is in this thread:
https://vansairforce.net/community/showthread.php?t=198447
Are you asking about safety, or reliability? My personal experience is that magnetos are not reliable. I have had varying degrees of failures on at least 4 occasions; however, they are safe because there are two of them and the the chances of them both failing at the same time is slim.
The p-mags had some early teething problems, but their reliability seems to be quite good now. All-in, p-mags are probably safer than magnetos too.
The other electronic ignitions all require external power. A very well though-out installation could be very safe, but many are vulnerable to pilot error.
My thoughts:
Carl
I run Bendix mags with Fine wire plugs, pretty much bulletproof system if you service them occasionally, and if there is a problem practically every mechanic in the world can help you fix them or has a spare laying around (not to mention all the shops that OH them).
I can do quite a few 500 hr mag checks for the cost of a set of PMAGS (which BTW are not install and forget). The ROI on PMAGS is slim.
Not against EI (I've had them all except CPI) but I think most people tend to overate the advantages and overlook the disadvantages (single source).
Still not a fan of bolting a CPU to the back of the engine, Sh*t gets awfully hot here in TX!
New is not always better, how often do you have to replace your home electronics/appliances now compared to 50 yrs ago.
Best of both world
Why not consider what so many of us have done.
One Mag and one EI.
For both of my Rvs I had a slick mag with impulse coupling and an LSE Plasma.
So far the only headache is the ongoing Service bulletin for my slick mags every 250 hours etc.
I do like the self contained magneto but I also enjoy the sophistication of the Plasma III. Its truly the best of both worlds.
I have over 6,000 aggregate hours in 5 homebuilts. Each has one Slick and one LSE Klausinator. If a Bendix mag would have fit, there would have been one Bendix and one LSE on each plane.
My criteria: 1) I shouldn't fall out of the sky 2) The plane shouldn't leave me stranded on the ground somewhere god forsaken, and 3) I can always launch when I want/need to.
One EI get me 90+% the benefits of having two EI's, but maximizes 1, 2, and 3 above.
Thanks for all the responses. I've made notes of the ignition options to consider. Right now, I plan to stay with my existing set-up of an aviation mag on the left and a P-Mag on the right. E-Mag offers great customer service and just took care of the problem with my P-Mag with a no-charge repair. More details are at this thread: https://vansairforce.net/community/showthread.php?t=198447
