Mid-stream in fitting the cowl for my 6A. Using hinges for the lower vertical and upper/lower joint. My plans show the larger 1/8" hinge for all areas except the upper/lower joint. Here they specify the smaller 257-p3 hinge. This seems a bit lightweight for the job and I have seen a post or two where the 1/8" hinge is used in this area. I have enough 1/8" hinge for this joint. Is that recommended?
Thanks for your guidance and insight.
Larry
Larry
