JamesClarkIV
Active Member
I mixed up my config modules. Help me figure out which is which. I have 3:
One for Garmin GSU73 (still in bag at left).
One for G3X GDU370 (PFD) (out of bag).
One for the Garmin GTN650 (out of bag).
Question, is the upper right one the 650 and the lower right module (looks similar to the GSU73) the one for the G3XPFD? I have placed them on top of the bags I think they came from, but am not sure.
I may have swapped upper right circuit board and lower right circuit board. Which is which?
https://flic.kr/p/o1M5TK
Jim
Jim
Jim,
I think you're right.
The G3x touch system only has 1 config module, and it looks like the GSU 73 module. Here is mine:
My GTN 650 config module has the connector in the middle (in your photo I can only see the back). Here's what mine looks like for the 650:
I think you have them right because the 650 config module does not have a gold plated screw hole in the PCB.
This mixup caused me to go label each one... good luck hope this helps!
Chris
