In the Vans store:
http://www.vansaircraft.com/cgi-bin/store.cgi?ident=1506386650-120-453&browse=engines&product=pump-carb
Backup pump
Thanks, I was given a new pump but was not sure what everyone else was using. Just finishing running my fuel lines inside of fuse..
I'm using a Facet Gold-Flow 40007 between my gascolator and mechanical fuel pump. It's rated at 36 GPH at 4.0-5.5 PSI, and has a 74u filter inside under that twist-off cap. It's "free flow" with no internal check valve. Self-priming to 24 inches vertical fuel lift. I mounted mine vertically, as recommended.
