Instructions say #1 and #4
...if you have a Vetterman crossover exhaust. I put the injectors just downstream of EGT probe location as instructed. Others have had good results installing the injectors much farther downstream. The Vetterman Exhaust slip-joints do leak a little so one could avoid this by installing the injectors downstream of the slip-joints.
The slip-joint leakage results in a little smoke oil to be wiped out of my lower cowling. Not a big problem.
