Carl Froehlich
I’ve typically used Potter & Brumfield or Tyco pull breakers in my panel builds. I did build one RV-14 panel using Klixon breakers. Other than the Klixon breakers small screws being a pain, all three brands have done well - as in no failures over 20+years.
I need to decide what product to use in the current build. The small size of the Klixon does not present an advantage in my build. Builder performance data is appreciated.
Carl
Have only used one, but happy with its performance over a couple years, have not had it pop but have pulled it out and reset it a few times, the little st patricks day colored klixon breakers.
