If you read thru the manual and then read thru again you will gain insight as to what to do first and then second etc. You have to think things thru so as to eliminate do over as much as possible. You will still have a few. the push pull tube to elevator bell crank is tough (read impossible) to install without removing the rod end bearings. When you figure that out it goes right in. If you are going to install system six position/strobes - plan where to put power pack. Think all your options thru. AOA computer goes where? etc. Some days I just spent reading and planning. But, this is my first time so there were many things I had to think thru. Van's gives very little direction on how to proceed with a QB.shiney said:After my holidays I will be pulling the QB fuse into the garage. I would like to know from QB builders where they started on the fuse. Any tips and ideas would be helpful.
Martin
