Michael Burbidge
How does one go about finding a good midtime engine?
Michael Burbidge
Sammamish, WA
Dreaming RV-9A
Michael Burbidge
Sammamish, WA
Dreaming RV-9A
except the inside of the crank barrel. The crank failed inspection from corrosion pits inside the barrel.
Just a note for everyone that once thought that if you failed an SB505 inspection the crank was done....Not in all cases now!
They are repairing some of these at this point. Seems lots of these cranks have enough meat in them to clean out the pits.
I just had mine repaired and recertified by Aircraft Specialties. Looks like a million bucks now!
...a certified O-320 core, then the crank is usually still good for a certified 150 HP O-320 - the SB505 only applies to the 160 HP version.
It should still have a good resale value....
Not sure I follow you here since this SB sez all O-320 engines are to be inspected and so does the AD that goes with this. Don't see the exemption based on HP???? Did rev A have the exemption? Seems Rev B does not. Must be why the price of cranks doubled over the past couple years.
<snip pic>
No big deal for experimentals, most have dismissed this SB as being worthless anyway.
....Aerosport guestimated $13,000 to overhaul a first runout engine for me. The seller wanted about $6,000. So for $19K I would have a freshly overhauled engine, while Aerosport could sell me a basic new one for $21K....
Well, I am not the only one slightly out date on new engine prices. Here is the current basic price schedule at Aerosport.
New Aero Sport Power 0-360 Series Engines:
with ECI Components $ 24,700.00 US
with Superior Roller Lifters $ 25,200.00 US
with Lycoming Roller Tappet Technology $ 26,200.00 US
At Lycoming the basic experimental YO-360-A4M is $28,750.
Brantel, where can you buy an 0360 kit for $17,500 today?
David,
Brantel's price quote is from his message dated 9-16-2008 (check the date stamp on his original message). I'm sure prices have changed since then.![]()
