samgaddis
Member
Hi all, one of my nose wheel fairing brackets fell off at some point. The fairing is undamaged but is now hanging on only by one side. I've simply removed it for now, but I can't find the replacement aluminum part on the Vans site. I could certainly track down the replacement screw and washers but does anyone know where I might find the U-1024 bracket part?
Image included for a visual.
It's a block of aluminum with a different part number "3/4 x 1 1/2 x 1 3/16 2024-T351 aluminum block" (U-1024 is the final part number, after you fabricate it).
If you'd rather not fabricate that piece, Aircraft Specialty sells them (that's what I used): http://www.aircraftspecialty.com/u1024.html
_Alex
