Deal fair,
Yeah, it WAS exciting. I don't know what caused it. The guy from Aymar was sure I hit something. There was nothing indicating any bird strike. It could have been a rock that started a chip/crack. I imagine it was a stress crack that I didn't notice.
My wife and I were heading on a little trip. I had just stopped to top off and we were still climbing around 8000 ft when it all of a sudden got very noisy and very rough. It was drastic enough my wife wife grabbed me. I eased the power back and started a turn towards the airport we had just left which was also the closest. I didn't know it was the prop. I thought I had lost a cylinder. There was a lot of vibration.
I quickly went through the engine monitor, all the cylinder numbers still looked normal. I was watching oil pressure, thinking maybe I had a valve stuck and bent pushrod, dumping oil, etc.. I just didnt know. I also was slowly varying rpm since that was greatly affecting the vibration. I found a couple rpm where the vibration was minimal. I used the lowest, smoothest rpm which was about 2000.
As I got near the airport I was still doing over 140kts so pulled the power all the way thinking maybe I'd find another smooth rpm way low. I was wrong, things really got to shaking and it scared my wife good (ok, me too). It was bad enough I killed the motor, pitched up to loose airspeed, threw in flaps, did a big funky S turn to loose altitude and turned final dead stick. It all happened really fast so I wasn't thinking, just doing.
It's funny, as I was flaring and touching down the prop had stopped spinning and was slowly turning over so I finally saw the big wedge out of the blade. I was so relieved thinking "thank goodness it's not some twenty thousand dollar motor just blew a hole in the side!". I rolled to a stop and my wife jumped out and starting hollering about the prop and then looked at me and said, "youre kinda pale".
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I just sat and relaxed for a few minutes waiting for all the adrenaline to let up.
I have had other "fun" flying events over the years and the saying about Always Fly the Plane First.....is good advice.
I am happy with the Sterba prop. My performance was a little off after first installing but it was related to something else not the prop.
