Ed_Wischmeyer
I started that plane some years back but divorce and a subsequent move made selling it the wisest choice. I know it went down to the Phoenix area...
And when I search for it on line by serial number, I don't find it, so I suspect it hasn't flown yet.
Anybody know where it is?
Ed
Ed
Not mine even thought it came from the Phoenix area... it's close but I bought s/n 0079 :)
When you buy parts from vans, you need to register your aircraft with them so you can purchase parts. I had to do this with my 6A when I took ownership of it. They might have the new owners name? Not sure if VANS would offer up info due to privacy issues but it's worth a jingle.
They definitely will help you out with that. When I was looking for local builders here I called Vans to see if they could hook me up with some local builders and they emailed me a spreadsheet with every builder and serial number in Kansas.
N10FD? Is this your plane?
https://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=10FD
Deregistered Aircraft 3 of 3
Aircraft Description
Serial Number
40090
Certificate Issue Date
04/09/2010
Manufacturer Name
D******* FRANK
Mode S Code (base 8 / oct)
50001334
Model
VANS RV-10
Mode S Code (base 16 / hex)
A002DC
Year Manufacturer
2009
Cancel Date
05/31/2013
Reason for Cancellation
Cancelled
Export To
None
Type Registration
Individual
Kit Manufacturer
VANS AIRCRAFT INC
Kit Model
RV-10
Aircraft Registration prior to Deregistration
Name
D******** FRANK P
State
NEW JERSEY
Zip Code
07090-1928
County
UNION
Country
UNITED STATES
Deregistered Airworthiness
Engine Manufacturer
LYCOMING
Classification
Experimental
Engine Model
41798
Category
Amateur Built
A/W Date
05/20/2009
Exception Code
No
