ArVeeNiner
I have a panel mounted Zaon MRX traffic alert system and I also have the antenna extender. For those of you who have a panel mounted unit and an antennal internal to the airplane, how did you mount the antenna?
My first thought is to drill a hole in the skin just under the windshield (slider installation) and then mount the antenna somehow. The coax connection on the stub antenna is at a right angle so you can't just simple push it up through the hole and secure it. The exender has a few inches of stiff cable that has suction cups on it in order to stick it to the canopy I assume. See it here: http://www.zaon.aero/component/option,com_wrapper/Itemid,65/
So, I thought I might pop it through the hole and then fashion some sort of bracket to hold the stiff area near the suction cups. I could just pop the antenna vertically through the hole and leave the stiff part of the extender and suction cups beneath the skin but I'm not sure that the stub would stick out the hole sufficiently. I guess I could look at routing the cable from beneath the panel.
Yes, using an external antenna is probably the best solution but I want to avoid that expense.
Anyway, just looking for better ideas.
