pilot28906
I am ready to rivet the bracing and have drilled the holes for the brake plate and fuel pump plate. When is the best time to drill the throttle, mixture, carb. heat, and the 2" hole; now or some time later?
Also, what is the best way to drill the 2 inch hole?
