Hey All,
I know the title of my post probably made some veteran builders shiver but hear me out. I'm building a RV8 Quick Build and have the tail finished and am working on the left wing. I have been a pilot since 1998 but this is my first build. I am an automotive technician specializing in electrical problems. I attended a RV Assembly Workshop. I left that workshop with the message you must use aviation hardware period. Here is my current source of frustration. In the automotive world I would absolutely never use a butt connector to join two wires. They corrode over time and cause random electrical problems. I always soldered wires and used heat shrink. I had a tech counselor tell me not to solder because vibration can cause the solder to crack, use butt connectors. I ordered Adel style clamps to hold the wires away from anything they could rub on but never thought about the small bolts and lock nuts I would use to attach them. Would hardware store bolts washers and lock nuts be ok? It just seems like every time I get started working on something I have to stop and wait 3 days for an Aircraft Spruce Order to come. I would like to put plugs on the back of my landing light wires. Are good quality plugs from NAPA ok or do they have to come from a place like Stein Air? I would never use hardware store bolts on anything important like flight controls, but it just seems like over kill for holding a Adel clamp to a wing rib. Thanks in advance for any advice.
