I think i have one. Ill check the model number today and get back to you shortlyDoes anyone have a power supply that I can buy? i have the old single strobe double flash on each wingtip. Model 0770062-03. 12v. I will eventually convert to LED but for now this is the quickest fix.
Bill
Thanks! If it works I’ll come get it. I’m in Lake CharlesI've got some old ones that were working when the LEDs were installed as an upgrade. I'll look when I get down there later today at the model number
I have three. Just removed last week. All work perfectly, no defects. I also have the entire Whelen strobe system (strobes / nav for tips and tail) if you're interested?Does anyone have a power supply that I can buy? i have the old single strobe double flash on each wingtip. Model 0770062-03. 12v. I will eventually convert to LED but for now this is the quickest fix.
Bill
Was that the multi light power supply? Mine is less current draw?
I just need the power supply for one strobe. You are in Beaumont?I have three. Just removed last week. All work perfectly, no defects. I also have the entire Whelen strobe system (strobes / nav for tips and tail) if you're interested?
It was out of a giles for strobes and nav. You can have it for $50 plus shippingWas that the multi light power supply? Mine is less current draw?
