Fleet
I'm New Here
Can anyone advise if is permissible to fly a RV 6A with the wheel pants off as I have heard the wheel pants should be left on.
Fleet
I am flying an RV9A and I am removing them for winter season. Flew without wheel fairings all the way to Alaska and back. Speed penalty vs reducing the risk on unimproved surfaces was worth it.
At Cordova CKU
Dry Bay AK3
Fleet
The factory recommendation is that you not fly without the nose wheel fairing as an extra precaution for protecting the nose gear.
For the main wheels it doesn't matter, but it is 50/50 either way.
Removing them protects them. Leaving them on risks damaging them but helps protect the rest of the airplane (particularly the bottom of the flaps and the Horz. stab. leading edge) from rocks and gravel, etc.
PROS & cons
Here's my list; I'm no bush pilot, just my $.02
PRO - leave on
speed & flight characterstics unchanged
keeps belly & wing clean & stab protected
nosepant keeps wheel aligned
slight protection from digging in to snow or soft ground
deicer chemicals not slung onto aircraft
CONs - slush can build inside pant...weight and possible wheel lock
- difficult to inspect or add air
PROS - all off
slush has fewer collection spots, (but still a few.)
easy to inspect, add air as temps drop
cons - nose wheel exposed, may not trail as well, may collect snow
