ZemsRV4
Member
I recently did the long gear mod on my RV-4 with the help of my mechanic who has built 9 RVs. The gear mod requires the two-piece pressure recovery wheel pants. We started them together but he has since given up helping me due to other projects. I did not build my plane and have little to no build experience. Looking for any help in pointing me to a video, blog or any other info source that can help me finish the wheel pants and associated fairings.
Zem
Why does the long gear legs mod require pressure recovery wheel pants?
My RV-4 project came with long legs and the old VA-108 one-piece wheel pants.
Now I'm debating whether to spend the $500+ for pressure recovery pants.
Finn
Maybe it doesn’t Finn. I guess I just assumed it did because my “expert” said I needed to get them when I bought the parts for the mod.
Get that section of the builders manual
I have one somewhere in my hangar but maybe vans has a file you could down load??
What kind of skills do you have? Drill a hole? Install nut plates
Measure and position the airplane?
Its not a tough job unless you cant do the above tasks
Cm
You can buy RV-4 plans on a disc from Vans for $10 and they should have all the details you need.
Can someone with RV-4, 6, 7, or 9 plans in a digital format just e-mail him the .pdf of the wheel pants installation plans? He could have 'em in his hands this afternoon. If you're up for that, just send him a PM asking for an e-mail address.
