RV7Guy
Hi Everyone,
Last annual (okay, Condition Inspection), I replaced the tires from the stock units. (I forgot the brand I put on) No problems, everything good. Fast forward to a couple of weeks ago.
I was flying to work, Chandler AZ to Yuma AZ. As I was about 30 miles out of Yuma, Approach Control announced the airport had just went IFR. The front edge of thunder storm was blowing dust across the field. I had the storm on the 496. Despite reporting the airport IFR, I could see it 20 miles out. Obviously the ground vis was much worse than the air visibility. I pulled out the Approach Charts and was cleared for the 17 VOR approach. No biggie despite being my first "real," IFR approach in the plane.
Did the approach, then asked for a Circle to land for a better wind situation. I had a left quartering head wind at about 25 knots, gusting to 30. Touched down and the plane bounced slightly. The second touch was not straight. Not a huge deal and I taxied in to our facility. (I've had worse!!)
The next day I flew to CA with no problems and returned later. When putting in the tie down rings I noticed cracked paint on the inside of the right wheel pant. Upon inspection, I discovered the tire had grabbed the back of the wheel pant and pulled the glass in and was very close to the glass, even with the minor damage. I checked the other pant and the gap was approximately 3/8," with full tire inflation. I knew the right tire was slightly lower than my normal pressure and was going to add the air while working my 7 days. One of those things that would hardly be noticeable to anyone else, but you know your own plane.
I took the wheel pant off and made minor repairs to get home for the real repairs. I discovered the right tire was down only 2 pounds from the normal 35lbs.
What I discovered was the new tires had a larger diameter. Comparing with the old ones it was at least an additional .5 inches. I took the time to open the holes in both wheel pants.
So, two things to consider. 1) If changing brands of tires, confirm your tire to wheel pant clearance. 2) Always keep your tire pressure accurate. Under normal circumstances, I probably would have been fine. With the slightly low tire pressure and the crosswind touch down, it was enough to deform the tire and grab the pant.
