I agree with Kyle's fix, I too use 1" snap plugs from the aviation aisle of Home Depot for access to the valve stems. Additionally, I aligned the stems with the 1" holes and then spray painted a 2" dot on the bottom inside of each tire. Now when I roll the dot vertical by the ground, the stem is aligned in the access hole. Dan
Several vendors sell small ~ 3/4 inch inspection doors for adding air to RV aircraft tires.
Do you find these to be useful? Convenient? Worth the effort?
Thanks for comments.
Interesting.
Is there a hidden issue behind the naysayers messages?
I think the hidden message is that they feel that they would not inspect the brake pads often enough, if they did not have to remove the fairing for adding air anyway.
