tyconnell
Can someone tell me what this tool is? It came with my Avery kit circa 8 years ago.
iRESXL4G8fVaR0L1uJ0_6wTmKJLVKAD8ECVl30zV5RuB-XV3kAcheYyV8zKMxAXE3Q0BYlEAmXF8DF7GfUQfKk13cXlvUlm1lYs7XkPGkYHcpRT8xiQhFgBfVs9ovrAE3WKtsK8QEitM1JJoi_MuUTMeVPQHG_d43e3HdYej8ig3eQ9xg8bTZGYtjFh2QKltor3WLuZFrPAO6hKoX87ils8qSPE873Jon25yWhPw2KE-oOewoY4HgjcepUURL42v36iQTqw5CapiQHbkCKZ6F10Skv71H4bM4f6phFu4kPP_BWKX65yTyOUj6sxsTJzwIIPtR9whA4oEFrjxTOc5fj53Vv9E4x4l8tvM9aPIz4C1fKHPeXpecPRSwPztmDJzOShppDEd0IbW09F1ZiFstVhBLHsW3w_w8MSwEcYNYcJoB3b4taDFDjvwjrpPcaWheyDcgM7Y7DUfzzdzRcP0dyzsFr5ML47LKP1T0rRdJ-EVIbDjE8sB0e7NutfNFrgexqHjpCXk0sdw72oCDfcCo12LxG8qO4XtGmydbbjC0p-6wSPsPweolXZOjOnKbfgXhWn3=w916-h150-no
I'm guessing it fits in a rivet gun and is used for ... riveting. A further guess is maybe back riveting in the C-Frame?
If that's correct, is there any advantage to the Cleveland back rivet conversion for the Avery C-Frame?
12" Back rivet set
Avery C-Frame converter
12" Back rivet set
It looks like the riveter that goes in the C-Frame. Is there a 3/16" hole in the end that is not shown in the photo? If it has a hole that a dimple die fits in, then that is what it is.
IMHO, the Cleaveland conversion is worth the mod. It will allow you to do more with the C-Frame than you could otherwise.
Sorry, should have done the whole photo the first time, trying to spare you all the "Zoomba" advert in the background:
R_sOkh_qTS6w_C8Ag83qudZIjtSI7iYh3z8aC9N9eQ3EHFm3R0eF5vQEh9eXyrMGvPbRwkonUX3ffA1sdmPhAnM18kMqz_y7mowFOzaMyRHeNiK5e-hZeV1FpnS2DXnVn-_nO22_LMP3X5oQECjqD_BdxL9T-UwbGCRJYGHJlTwrAZGCHaY7H2UUDNFOV3QjGOtwr-XmL6SIfwKbfkr4M71OL9QFFpyCITNSf_f9gM8Bh1-CCxJGQK-srHnWTIKtUlnbXU1F8bNb8M9lRmy0rM3_etGs7U3CprkcSy7EdgzV5UGiDFyojYrocBQ8N8KyFzzI62xbgRDbiv5e7vXuFguByl9MRqjbVqWM_3wfbqmLQUFBkjJMb_8yUo9xgERfP6YV9WOXurBzzR1UHtjCsox3ipEBoKp5i8p99LrKhpSYtyxcOqVhsiKsFW2fi53GfoO6liwYefRq5vHvRjkuIQcBvDtFQgvdE6Qp44BmXRCmsf0USdlNcAI8iQ99RBIJeBlNSnNLYr-tbWMSYjA3221wy0SlwBCVIo_0nHi5bplCtYJdiPd3vLzn92fVDt9tAzEE=w948-h404-no
The one on the bottom is the one you are referring to. Just didn't know what the flat, no hole one on the top was.
With the hole: Put a rivet set in the end, whack with a mallet. You can use either a flat or universal set on top or bottom, and either "rivet" or "back rivet".
Without the hole: Flat or universal rivet set goes on the base, drive with rivet gun to "back rivet".
