ron sterba
Well time to put N number on plane. What size does USA and Canada require? Three inch or two inch for. USA? Canada? May want to go to Victoria BC sometime. Thanks
Ron in Orego
Ron in Orego
Because the design is over 30 years old, the RV-3, -4, and -6 may use 2" numbers as long as the maximum cruise speed is not over 180 kts.
Yes, and the 12" numbers do NOT have to be permanent.OK. Let's see if I have this straight. One can fly US-Canada and return with 3 inch letters (or 2" if applicable). To fly to Mexico or other points south, one needs 12 inch letters only for the return trip. Do I have that right? Thanks.
Cheers, David
"which has the same external configuration as an aircraft built as least 30 years ago"
2 wings, near bottom of fuselage, tail in the back, motor in the front, 2 seats (but that's not external, of course).
Sounds like I can use 2" numbers on my -7.
Charlie
I wouldn't push it! We have a lot of privileges. Let's not abuse them.
Technically, the RV-6A does not meet FAAs definition. The landing gear IS part of the configuration. And the 6A didn't come out until the early 1990s.
Well, the -7 is essentially the same external configuration as the -6...
If Vans N666RV is the first RV-6A then it was a little earlier than you say.
Certificate Issued 04/21/1988
Just under two years to wait to use those 2 inch letters and an "NX" in the painted registration numbers.![]()
Who said anything about an A? I (don't) resemble that remark!
I don't care much about 2" vs 3" numbers... I want to be able to use an NX number...
If I read the regs right, a newly certified 6 could be painted with 2 inch "NX..." numbers AND not require the "EXPERIMENTAL" placard. Mel- is that correct?
Got a few years to wait with the RV-7. How about 2031.
That is correct. the "X" does not show up on any paperwork, and is never used in radio communications. It simply replaces the "EXPERIMENTAL" placard.
Good for them since this is no size requirement for travel to/from Canada, just don't expect the same treatment from U.S. Customs if you arrive from the South. They will pull out a tape measure if there appears to be a violation.I actually just talked to a Canadian Customs and Border agent about this a couple weeks ago... They could care less about the size of N numbers, and he "never pulled out a tape measure to check"...
