rvator10
Patron
I'm running some price numbers on building a RV14A and don't want to duplicate some big ticket items. please help me understand what are the big ticket items in the -14A FWF kit thats $7k? yes i asked vans 3 times and received 3 different answers all that didn't make an sense.:confused:
thanks
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
Customer: NB0000 / PACKING LISTS
Customer: NB0000 Shipping address: PACKING LISTS
PACKING LISTS
Telephone:
Email:
Shipping Instructions:
*NB0000* 1 *045551*
04/06/17 04/06/17 Default
Order Date Scheduled Ship Salesperson Purchase Order
045551
Sales Order Ship Date
Pulled By: Checked By:
Picked Rec'd Ship quantity Stock code Bin Description
1.000 RV-14A FIREWALL FWD. KIT F.WALL FWD KIT TRI-GEAR
1.000 F.WALL FORWARD COMMOM 14/14A ------------SUB KIT--------
1.000 14 PLANS FWF 14/14A SECT. 43,44,49,50,51
1.000 AT0-035X3/8X18 S1F SOFT ALUM TUBE
1.000 AT6-058X5/16X15 7/8 F7A S1C ALUM TUBE
1.000 BAF-14-IO 360/390 ANGLE VALVE 200/210 HP
1.000 BAG 1115 AN470AD3-4
0.010 AN470AD3-4 RIVETS (LB)
1.000 BAG 2602 RIVET AN426AD3-3.5
0.010 AN426AD3-3.5 RIVETS (LB)
2.000 BAG 3221 AN470AD3-3.5
0.020 AN470AD3-3.5 RIVETS (LB)
1.000 BAG 565 BAFFLE HWR 390
7.000 AN3-3A BOLT
3.000 AN3-4A BOLT
1.000 AN4-16A BOLT
4.000 BOLT HEX 1/4-20X3/4 DH HW DRILLED HEX BOLT 11100479
7.000 K1000-3 HW PLATENUT 10-32 MS21047L3
1.000 K1000-4 HW PLATENUT 1/4-28
12.000 NAS1149F0363P HW REPLACES AN960-10
13.000 NAS1149F0432P HW REPLACES AN960-416L
1.000 BAG 566 BAFFLE HWR 390
8.000 AN507C632R8 SCREW,FLT HD SS
1.000 AN509-8R8 SCREW,FLT HD STRUCT
13.000 AN515-8R8 SCREW,ROUND HD
1.000 AN525-10R10 SCREW,WASHER HD
8.000 K1000-08 HW PLATENUT 8-32 Kaynar
Page 1 of 8
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
1.000 MS21042-08 HW 8-32 METAL LOCK NUT
14.000 NAS1149FN832P HW REPLACES AN960-8
1.000 BAG 567 BAFFLE HWR 390
1.000 AT6-058X3/8X2 ALUM TUBE
18.000 MS21042-06 HW 6-32 METAL LOCK NUT
1.000 MS21919DG7 HW CUSHION CLAMP 7/16
1.000 MS21919WDG6 HW CUSHION CLAMP 3/8
3.000 NAS1149F0632P HW REPLACES AN960-616L
10.000 NAS1149FN632P HW REPLACES AN960-6
2.000 WASHER 5610-18-31 NYLON WASHER #8 SCREW
1.000 BAG 568 BAFFLE HWR 390
4.000 CB8-31 ENGINE PLUG INSERT
5.000 K1000-08D HW NUTPLATE-RIVET HOLES DIMPLED
11.000 MS35206-281 HW 1/4-20 BAFFLE SCREW
2.000 MS35206-309 HW 3/8-16 PHP FOR BAF
4.000 MS35333-39 HW 3/16 INT TOOTH L/W
16.000 MS35333-40 HW 1/4 INT TOOTH L/W
2.000 MS35333-42 HW 3/8" INT TOOTH L/W
1.000 BAG 569 BAFFLE HWR 390
80.000 RIVET AAPQ 4-3 ALUM POP RIVET
80.000 WASHER-00009 .128x.500x.016
1.000 BAG 958 AN426AD3-4 RIVETS
0.010 AN426AD3-4 RIVETS (LB)
1.000 CB-00001 S2D CYL #2 BAFFLE -14
4.000 CB-00002 S2D FORWARD DOUBLER
1.000 CB-00003 S2D CYL #1 BAFFLE
1.000 CB-00004 S2D FWD CENTER BRACKET
1.000 CB-00005 S2D FWD RT BAFFLE MOUNT
1.000 CB-00006 S2D LEFT AIR DAM
1.000 CB-00007 S2D RIGHT AIR RAMP
1.000 CB-00008 S2B FWD LFT BAFFLE MOUNT
1.000 CB-00009 S2B LEFT AIR RAMP
2.000 CB-00010 S2B BAFFLE MOUNT
1.000 CB-00011 S2B FWD LEFT BAFFLE
1.000 CB-00012 S2D Right Forward Baffle
1.000 CB-00013 S2B RIGHT AIR DAM
1.000 CB-00014 S2B CYL #3 BAFFLE
1.000 CB-00015 S2B RT AFT BAFFLE
1.000 CB-00016 S2D AFT CENTER BRACKET
1.000 CB-00017 D2B LEFT AFT BAFFLE
1.000 CB-00018 S2B BAFFLE BACK PLATE
1.000 CB-00019 S2B CYL #4 BAFFLE
1.000 CB-00020 S2D Air Filter Frame
1.000 CB-00023 S2C BAF BACK PLATE CAP
1.000 CB-00028 S2C CYL #3 BRIDGE
1.000 CB-00029 S2C CYL #3 BRIDGE LEFT
1.000 CB-00030 S2C CYL #3 BRIDGE RIGHT
Page 2 of 8
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
1.000 CB-00032 S2C Silicone Baffle Kit
1.000 CB-00033 S2C Air Filter Frame Cover
1.000 CB-00034 S2C Right Air Ramp Cone
1.000 CB-00035 S2C Snorkel Drill Template
1.000 CB-00036-L S2C Clamping Strip Left
1.000 CB-00036-R S2C Clamping Strip Right
2.000 DUCT CBT-5/8 S3A COOLING BLAST TUBE
1.000 E-33-2060 S3B AIR FILTER (IO-360)
1.000 MANUAL-14 SECTION 47 BAFFLE INSTRUCTIONS IO-390
1.000 PT-062X1/4X20" S7C HI PRES BAF KIT TUBE
2.000 SSP-120X2' STAINLESS STEEL PIN
1.000 VA-132-2 S9A IO SNORKEL
1.000 VA-187 S9D 4" FLANGED DUCT
1.000 VA-192A S9E ALT.AIR INLET
1.000 VA-192B S9E FILTER BYPASS DOOR
1.000 VENT DL-03 S9F 2" ALUM FLANGE
1.000 VENT SCREEN 3X3 INLET SCREEN ALUMINUM
1.000 BAG 511 AN3 FWF 14/14A
1.000 AN3-10 BOLT
3.000 AN3-3A BOLT
8.000 AN3-41A BOLT
4.000 AN3-4A BOLT
2.000 AN3-6A BOLT
1.000 AN310-3 NUT,CASTLE 3/16
2.000 AN320-3 NUT,CASTLE SHEAR
9.000 AN525-10R10 SCREW,WASHER HD
6.000 AN525-10R7 SCREW,WASHER HD
2.000 AN525-10R8 WASHER HD SCREW
4.000 K1000-3 HW PLATENUT 10-32 MS21047L3
20.000 MS21042-3 HW 10-32 METAL LOCK NUT
4.000 MS24665-132 HW COTTER PIN
26.000 NAS1149F0332P HW REPLACES AN960-10L
1.000 BAG 512 AN4 FWF 14/14A
1.000 AN816-4D NIPPLE,PIPE-TUBE
1.000 AN816-6D NIPPLE,PIPE-TUBE
1.000 AN816-8D NIPPLE, TUBE-PIPE
1.000 AN822-4D ELBOW 90DEG TUBE-PIPE
1.000 AN822-8D ELBOW 90DG TUBE-PIPE
1.000 AN823-6D ELBOW 45DEG TUBE-PIPE
1.000 AN823-8D ELBOW 45DG TUBE-PIPE
2.000 F 1/8 PIPE PLUG HW STEEL ALLEN HD PLUG
1.000 F 69-F-04X02 HW BRASS ELBOW W/FERRULE
1.000 KB-090-T S6E 3/8X3/8X1/8 PUMP TEE
2.000 VA-128 RESTRICTOR, OIL/FUEL
1.000 BAG 513 CLAMPS 14 FWF
2.000 AN737TW-38 HOSE CLAMP 1 1/2 SS
2.000 EA 4" DUCT HOSE CLAMP S3B 4" HOSE CLAMP
3.000 HW-00006 CLAMP,CORBIN .583-625
Page 3 of 8
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
1.000 MS21919DG10 HW CUSHION CLAMP 5/8
2.000 MS21919DG11 HW CUSHION CLAMP 11/16
7.000 MS21919DG12 HW CUSHION CLAMP 3/4
2.000 MS21919DG14 HW CUSHION CLAMP 7/8
2.000 MS21919DG2 HW CUSHION CLAMP 1/8
1.000 MS21919DG4 HW CUSHION CLAMP 1/4
8.000 MS21919DG5 HW CUSHION CLAMP 5/16
3.000 MS21919DG7 HW CUSHION CLAMP 7/16
2.000 MS21919WCH26 HW CUSHION CLAMP HIGH TEMP
7.000 MS21919WDG3 HW CUSHION CLAMP 3/16
3.000 MS21919WDG6 HW CUSHION CLAMP 3/8
1.000 BAG 514 FWF Hwr 14/14A
1.000 AN4-12A BOLT
1.000 AN4-4A BOLT
5.000 AN4-5A BOLT
2.000 AN525-8R8 WASHER HEAD SCREW
3.000 MS21042-08 HW 8-32 METAL LOCK NUT
2.000 MS21042-4 HW 1/4-28 METAL LOCKNUT
2.000 MS35333-40 HW 1/4 INT TOOTH L/W
22.000 NAS1149F0463P HW REPLACES AN960-416
3.000 NAS1149FN832P HW REPLACES AN960-8
1.000 BAG 515 FWF Hwr 14/14A
1.000 BEARING MW-3M HW ROD END THROTTLE CABL
2.000 BUSHING SB625-7 HW SNAP-IN 7/16ID 5/8 OD
1.000 EA LW-75444 S3D SNIFFLE VALVE
2.000 MS24694S72 HW 100 DG FL HD MS
18.000 NAS1149F0363P HW REPLACES AN960-10
2.000 NAS1149F0432P HW REPLACES AN960-416L
2.000 VA-181-1 WIRE NUT
1.000 WASHER 5702-475-48 Z3 .190X.562X.048 WASHER
2.000 WASHER 5702-75-60 STEEL WASHER FOR AN3
1.000 BAG 547 SENSOR KIT 14 AFS/DYNON
2.000 AN3-11A BOLT
1.000 AN840-4D HOSE NIPPLE 1/4"ID TUBE - PIPE THREAD 1/8NPT
2.000 HW-00010 Spring,Hose Clamp
1.000 BAG 548 SENSOR KIT 14 IO-390 GARMIN
1.000 AN3-4A BOLT
1.000 AN525-10R7 SCREW,WASHER HD
1.000 AN931-6-16 GROMMET,3/8 ID, 1" OD
1.000 F 4 DTX-S ELBOW TUBE-PIPE 1/4 S
1.000 F-00036 FUEL PRESS.SNSR.BRCKT
1.000 BAG 572 Electrical FWF 14/14A
1.000 AS3-063X3X3 ALUMINUM SHEET 2024-T3
1.000 EA HOSE H177X3 3" LONG HOSE
Page 4 of 8
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
1.000 ES HST-1/2X3 Heat Shrink 1/2 x 3"
1.000 FF-00076 Bracket,Sniffle Line
1.000 MS21266-1N HW GROMMET STRIP 12"
6.000 MS25171-1S HW NIPPLE (BOOT) SMALL
5.000 MS25171-3S HW NIPPLE (BOOT) LARGE
30.000 PLASTIC TIE WRAP 4" 4" PLASTIC ZIP TIE
4.000 PLASTIC TIE WRAP 8" 8"PLASTIC TIE
1.000 BAG 924-3 C/S SPINNER HARDWARE
0.020 AN470AD4-5 RIVETS (LB)
4.000 AN4H4A BOLT
22.000 AN526C832R8 SCREW,TRUSS HD SS
22.000 K1000-08 HW PLATENUT 8-32 Kaynar
12.000 NAS1149F0463P HW REPLACES AN960-416
22.000 WASHER 5610-18-31 NYLON WASHER #8 SCREW
3.000 CT A-740 BLACK PUSH PULL CABLE BLACK
1.000 CT BLK THROTTLE 51 S9C THROTTLE CABLE RV-14/14A IO-390
1.000 CT BLUE VPROP 58 S9C PROP CONTROL CABLE RV-14 IO-390
1.000 CT RED VMIXTURE 54 S9C Mixture cable RV-14 IO-390
1.000 EA CV HOSE 9816 S3C BREATHER HOSE 4 CYL
1.000 EA DYNA BOLT 3C BOLT SET 4 CYL DYNAFL
4.000 AN310-7 NUT,CASTLE 7/16
2.000 AN7-43 BOLT-DYNA MOUNT
2.000 AN7-44 BOLT-DYNA MOUNT
2.000 AN970-7 WASHER 1 13/16 OD
4.000 MS24665-283 HW COTTER PIN 3/8 BOLT
10.000 NAS1149F0763P HW REPLACES AN960-716
4.000 EA DYNA VI-STD S3C VIB.ISO.ALL EXCEPT-10
1.000 EA EXH 14 S11 EXHAUST SYSTEM KIT RV-14/14A I0-390
1.000 BAG 558 14 Exhaust Hwr
11.000 AN737TW-66 S1C HOSE CLAMP 2" SS
4.000 AN737TW-91 HOSE CLAMP 2.5" SS
4.000 EA GASKET 77611 S3D BLO-PROOF EXHST GASKT
1.000 F-01469 HW LINK, MUFFLER HANGER
4.000 MS21919DG12 HW CUSHION CLAMP 3/4
3.000 MS21919DG32 HW CUSHION CLAMP 2"
8.000 MS35333-41 HW WASHER, INT LOCK 5/16
8.000 NAS1149F0563P HW REPLACES AN960-516
8.000 NUT-00003 HW EXHAUST SS 5/16 HEX
1.000 BAG 559 14 Exhaust Hwr
1.000 AN3-12A BOLT
6.000 AN3-13A BOLT
4.000 AN3-4 BOLT
4.000 AN310-3 NUT,CASTLE 3/16
2.000 AN525-10R10 SCREW,WASHER HD
1.000 BUSH AL.197X.313X.968 ALUMINUM BUSHING
4.000 BUSHING TFI-0304-04 HW 12 TRIM BUSHING
Page 5 of 8
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
11.000 MS21042-3 HW 10-32 METAL LOCK NUT
1.000 MS35333-40 HW 1/4 INT TOOTH L/W
10.000 NAS1149F0363P HW REPLACES AN960-10
4.000 NAS1149F0463P HW REPLACES AN960-416
18.000 NAS1149FN632P HW REPLACES AN960-6
6.000 SPRING 13/32X1 COMP COMPRESSION SPRING
3.000 EA LV-1 HEAT SHIELD S3D EXHAUST HEAT SHIELD
1.000 EX-00004 S11C 1 3/4" HANGER KIT
1.000 EX-00004G S4C EXHAUST HANGER BRKT.
1.000 EX-00006 TAILPIPE MERGE
1.000 EX-00011 Exh.System Fwd. 360/390 Angle Valve
1.000 EX-00012 Exh.System Aft 360/390 ang.valve
8.000 EX-00013C HEAT MUFF ENDCAP
1.000 EX-00013E S4C Heat Muff ,Aft.
1.000 EX-00013F 4C Heat Muff,Fwd
4.000 EX-00013G S4C Heat Muff Rod
1.000 FF-00084 S5B Vent Block Off
1.000 MANUAL-14 SECTION 48 EXHAUST SYSTEM IO-390 RV-14/14A
1.000 VENT DL-04 S9F 2" DUCT ELBOW
1.000 VENT SCAT 2X6' F5B S11G SCAT TUBE X 6 FT
1.000 VENT-00002 S9E TEE,2" DUCT
1.000 EA HOSE H175X24 HOSE 1/4" ID
1.000 EA HOSE H177X12 S3C 12" LONG HOSE
1.000 EA-00002 S3E OIL COOLER 2006X RV-14 13 ROW
1.000 ES 24021 S3F STARTER SOLENOID 2OUT
1.000 ES 24115 S3F MASTER RELAY
1.000 ES ALTERNATOR DELUXE S11E 60A KIT W/OV PROTECT
1.000 ES DIODE MASTER S4E MSTR RELAY PROTECTION
1.000 ES DIODE STARTER S4E STRT RELAY PROTECTION
1.000 ES PC680 S11E BATTERY ODYSSEY 12V
1.000 F AE102-11X1 FT Fire Sleeve 12"
1.000 F-14107 S4A BRACKET CONTROL CABLE- PANEL
1.000 FF-00004 S5A TUBE,BREATHER
1.000 FF-00009 S5B GOVERNOR BRACKET
1.000 FF-00014 FOR GARMIN SENSOR KIT -RV14
1.000 FF-00015 S5B Hose Assy.6x11.125--14 TG/TD
1.000 FF-01403A S5B ANGLE,BATTERY BOX
1.000 FF-01406B S5B OIL COOLER VENT
1.000 FF-01406C S5A S5B OIL COOLER INLET SIDE
1.000 FF-01411 Seal,Battery Box Angle
1.000 IE DYNON FF S5D ELEC INT 100403-003
1.000 IO-360 THROTTLE/MIX S6E CABLE ATTACH KIT FWD
2.000 AN3-10 BOLT
1.000 AN3-11 BOLT
1.000 AN3-14 BOLT
1.000 AN310-4 NUT,CASTLE 1/4
Page 6 of 8
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
2.000 AN315-3R NUT,JAM 3/16
1.000 AN316-4R NUT,THIN JAM 1/4
1.000 AN4-10 BOLT
2.000 AN4-15A BOLT
1.000 AT6-058X5/16X4 HW ALUM TUBE {INCHES}
1.000 BEARING F3414M HW 3/16X1/4FEM R/E BEARG
1.000 BEARING M3414M HW 3/16X1/4 MALE RD END
2.000 BEARING MW-3M HW ROD END THROTTLE CABL
2.000 BOLT HEX 1/4-20X.5 DH HW 1/4-20X1/2 DRILLED HD
1.000 DOC OP-22 INSTALL IO-360 THRTLE
2.000 MS21045-4 HW 1/4-28 METAL LOCK NUT
1.000 MS24665-208 HW COTTER PIN - CLEVIS
8.000 NAS1149F0463P HW REPLACES AN960-416
1.000 VA-163-PC IO-360 MIXTURE BRAKET
1.000 VA-164-PC IO-360 MIX.BRACKET
1.000 VA-165-PC IO-360 MIX.BELLCRANK
1.000 VA-173-PC IO-360 THROTTLE BRKT.
4.000 WASHER 5702-475-48 Z3 .190X.562X.048 WASHER
12.000 WASHER 5702-75-60 STEEL WASHER FOR AN3
1.000 PROP GOV HZ IO-390 S7B S-1-79 FOR RV-14
1.000 PT-035X1/4X 18 S7C 18" Fuel Overflow Tube-14
1.000 S-601-1 F3C F4 S7DFG SPINNER BOWL 13"
1.000 S-602-1 F3C S7D FP,CS,SEN 13"BACK PLT
1.000 S-602B F3A S7D CS BACK PLT DOUBLER
1.000 S-603 F3A S7D FRONT BLKHD CS 7 7/8"
1.000 SEAL-00008X12 S7F P SEAL 12 "
1.000 VA-102 S9A FUEL PRES. HOSE 16
1.000 VA-119 S9A IE VMP HOSE 21.5
1.000 VA-139 S8B FUEL SUPPLY HOSE 16.5
1.000 VA-168 S9D SENDER MOUNT
1.000 VENT SCAT 4X21" S11G 4" DIA. RED SCAT HOSE
1.000 WH-K1066 S10D Relay Interconnect Bar
1.000 WH-K910 S10D STARTER DISENGAGE WIRE
1.000 WH-P16 S10C #2 ELEC.CABLE 30"
2.000 WH-P25 S10C #2 AWG BRAIDED 7.25"
1.000 WH-P769 S10C Starter Relay PWR Cable 16"
1.000 WH-P909 S10C ALTERNATOR WIRE #8 48"
1.000 WH-P912 S10C BATTERY POWER LINE #8 38"
1.000 F.WALL FORWARD-14A UNIQUE UNIQUE 14A TRI-GEAR PARTS
1.000 BAG 573 FWF Hwr 14A Unique
1.000 KB-000 S6E STRAIGHT A/C OUTLET
1.000 FF-00019 Hose Assy. 6x19 --14 TG
1.000 FF-00020 S5B Hose Assy. 8x19--14 TG
1.000 FF-01404 S5B TRAY,OIL COOLER
Page 7 of 8
Packing List
045551
VANS AIRCRAFT, INC.
14401 N.E. KEIL RD.
AURORA, OR 97002
1.000 FF-01404A S5B SUPPORT,OIL COOL TRAY
1.000 FF-01405 S5B BRACE,CHANNEL
1.000 VA-190 S9E OIL COOLER HOSE 27"
Order Deletions
End of List
WEB ORDER NOTES
Page 8 of 8
