macrafic
I have a couple of places where I drilled "extra" holes (read "mistakes"). These are #30 and #40 drill-size holes in the aluminum. It's easy enough to rivet in a backing plate and fill the holes, but I'm not sure what to fill them with.
I've read through the forums and found that bondo will shrink; not desirable. Other fillers will crack. Any suggestions? Especially from those of you having used fillers in your plane and been flying them a while.
Thanks.
Thanks.
