I'm coming to the end of the work on the tail of my RV-7, and I don't want a long break in building, so I want to order the next set of components soon. I was wondering, which part is best to build next, the wings or the fuselage? Thanks!
Personally I go for the fuselage next. It takes longer to build and is easier to move around after completion. Wing construction goes very fast.
Can you order the fuse without the wings or before the wings? My 7 wing kit came with the center section spars that were a matched set with the wing spars. You need these to build the fuse.
I would build wings first for reasons mentioned. With CNC parts the center section no longer has to be matched to the spars. However, destructions get really abbreviated on the fuse. It helps to have that experience in the builder bank.
