I'm want to clean and regap or replace the spark plugs on the RV-4 I bought a couple of months ago. This is my first airplane and I've never worked on this stuff before. I've perused Aircraft Spruce's sparkplug tool offerings but I'm not sure what's really needed.
The engine is an IO-360-A1B with dual slick mags. The plugs are Champion REM38E.
Here's a breakdown of the issues I can think of:
Socket:
E.g.: Do I need to use a torque wrench? I never bothered when working on auto or motorcycle engines but maybe it's more critical on a Lycoming.
Kev
Socket:
Is 7/8" the correct size?
ACS sells this one for ~$50:
http://www.aircraftspruce.com/catalog/topages/gapsettingtool5.php
Is there a more reasonably priced aircraft plug socket?
Can I just use a standard deep socket?
Cleaning:ACS sells this one for ~$50:
Does the "clean screen" work? http://www.aircraftspruce.com/catalog/topages/gapsettingtool6.php
or should I resign myself to setting up a sandblast type cleaner in the hangar (including air compressor)?
Gap adjustment:or should I resign myself to setting up a sandblast type cleaner in the hangar (including air compressor)?
Wire type feeler gauge or flat?
Do I need special gap-setting tools such as these?
http://www.aircraftspruce.com/catalog/topages/precisegap.php
http://www.aircraftspruce.com/catalog/topages/electrodespreader.php
Thread protection:Do I need special gap-setting tools such as these?
Do I need a thread chaser?
Do I need to use thread antisieze?
Any tips or guidance about standard practices would be appreciated.Do I need to use thread antisieze?
Kev
