Cannot Share Comm Antenna
You cannot share one comm antenna between two comms like you can with nav receivers. The reason is that comms both receive and transmit. Navs only receive. If you try to use one comm antenna with two comms connected via splitter you'll either overload the non-transmitting comm's receiver or smoke the transmitting comm's transmitter.
Each comm must have it's own antenna.
I plan to use two RAMI or Commant bent whip antennas on the belly (just behind the main spar under the removeable seat panels, as Greg stated) spaced as far apart as possible. This will also place them at least three feet from my transponder antenna, which is mounted on the belly just aft of the baggage compartment.
Also it is important that none of the antennas be installed in the flow of the exhaust.
Use doubler plates and ensure you get a good ground for all skin mounted antennas by removing paint, primer, etc at the attach point.
