Finley Atherton
I am thinking of the scenario where you have had an engine failure and have successfully glided to the landing area and now need to lower some flaps, descend, flare and touchdown.
My normal (engine producing power) short field, full flap, over the fence speed is about 55 kts and I know when the throttle is pulled back the rate of descent increases dramatically so I have always thought this would be too slow with a dead engine. I decided to conducted some tests where I pulled the mixture back to idle cutoff (dead engine) at about 150 ft above the runway with full flaps at various speeds.
At 65 kts the rate of descent was scary but there was plenty of power in the elevators and wings to stop the descent and flare. At 60 kts the rate of descent was frightening and there was only just enough in the elevator and wings to flare. These flights were done solo with about 1/3 fuel and with the prop full fine. I did one dead engine landing at 60 kts with the prop full coarse which gave a much gentler rate of descent and an easy flare.
So:
Light weight, full flap, prop full fine, min speed 65 kts
Light weight, full flap, prop full coarse, min speed 60 kts (could be less but I didn't try any slower as the prop might stop and the drag would increase, possibly at a critical time in the flare).
These are minimum speeds and I would possibly add 5 kts for a safety margin plus at least another 5 kts at heavier weights.
This is for my 9A and I guess you might want to be faster in the short wing Rvs?
These flights were with full flap. In a real emergency, if possible I think I would try to avoid using a lot of flap until very near the ground (maybe 10 to 15 ft). Manual flaps would be best in this situation.
I am not suggesting others should do full flap, dead engine landings at low speed. The rate of descent can be frightening and it may ruin your day if you mess up the flare. I won't be doing any more, but it was an eye opener.
Fin
9A. 0-320, Hartzell.
So:
Fin
