Is there a country-wide war game exercise going on or something? There are Danger zones lining both coasts, and what looks like hundreds of TRF and warning areas dotting the entire country. What is going on?
The Restricted Areas 3005A-E, southwest of Savannah, are almost always hot. When you do get to fly through them, there's all these things you've never seen before...
Here is the blurb on the new graphical enroute NOTAMs shown in ForeFlight. They are all toggled ON by default. They can be all toggled off with one toggle, or each of them can be toggled off. Watch the short embedded video.
“Global Graphical NOTAMs
Previously limited to Europe, Graphical enroute NOTAMs are now supported globally with the new NOTAMs map layer. NOTAMs are color-coded red, yellow, or gray based on type, severity, and active times. Additionally, with the NOTAMs layer enabled, you can selectively filter which types are shown using the new menu in Map Settings > NOTAMs Settings, with toggles for Exercises, Controlled Airspaces, Obstacles, and Other.”
