hevansrv7a
I was reading the CAFE report on the -6A. They give calculated "thrust horsepower" THP which seems to NOT be speed times drag. Shouldn't it be? I know this is not obvious from what they published. I built a spreadsheet to iterate the values for parasite and induced drag according to the usual rules and my numbers for drag at 180 mph, starting with CAFE's numbers,agree with theirs. When I extend my iterations to the higher speeds that they use for THP I get a significant difference from TAS x 5280 / 60 * total-drag. Since my iterations start at best L/D = 106 mph and still agree at 180 mph, I'm assuming it's not my curves that are the problem. Therefore I'm stumped. A search of the internet seems to say that THP is speed times drag. Any experts care to help out?
I note as a possible area of explanation that the drag polar graph is in CAS but the formulae just below it are necessrily in TAS because altitude is not given. Is the difference between CAS and TAS the problem here? Which is more correct for drag measurements, CAS or TAS?
I am building a spreadsheet which will, I hope, make it easier to evaluate changes to engine, prop and/or airframe and will require only TAS or CAS at MinSink and the values of MinSink, sink at MaxL/D and aircraft weight as initial inputs. It's too ugly to share yet. The first sheet in the book is built to use the CAFE report's numbers to prove it gets the right results. The next page will be my 7A's. I will be pleased to share this when it's getting good answers for the CAFE 6A.
