Gregg, Once you use it you will find all kinds of uses for it. I find I reach for it often to work an edge down or roll a corner. DonGregClawson said:Thanks folks. Looks like its time to add a body hammer and dolly to my tool inventory...I doubt this will be the only time I need these before the plane is done! I am very glad that I never intended to leave it bare metal; paint will hide a lot of mistakes!![]()
Actually, in this case, if your outtie is on a flat part of the wing skin, just put a heavy, flat bucking bar behind it and tap it at low pressure with the flush set in your rivet gun. If the dent isn't too big, there might not even be much to fill. Probably no need to buy any body shaping tools at this stage, if ever, though it does sound like others think them useful. Good luck.GregClawson said:Thanks folks. Looks like its time to add a body hammer and dolly to my tool inventory...I doubt this will be the only time I need these before the plane is done! I am very glad that I never intended to leave it bare metal; paint will hide a lot of mistakes!![]()
