Thanks for the pics, so I need to fit my spinner first ya? that paint came out beautiful! did you have to do any pin hole filling?
On sky bolts just space out and watch spacing on cylinder heads.
Use .032 strip on bottom cowl.
Boomer
Do we still need a strip on the bottom? is this for strength or to hid a gap, on the SkyBolt kit it comes with the mount plates and they say to raise the thing E so it is .250 up, to leave no gap visible?
Thanks for the links Bill, so, the tabs will not work on the split, because of the compound? and where do you start on the FW tab to get it lined up with the split row? line up the top or bottom first? looks like I am going to be cowl and decowling a couple hundred times ya?
