prkaye said:Can someone explain to me what, technically, the difference is between an IFR-GPS and a non-IFR GPS? Is it just a matter of having all the GPS approach coordinates programmed into its memory? Or is it just a matter of the legal status of its certification?
jcoloccia said:The 2 biggies are the database and RAID.
$8500 - $2700 = $5800Yukon said:Many technical differences but the big difference is price. Garmin 496 2700 bucks. Garmin 430 - $8500 with indicator.
I don't know either, but I'd trust my '496 more than I would trust my VOR, let alone an ADF. If a handheld puts you 2 miles off course, there is more wrong than a TSO would fix IMHO. I've seen more ILS outages than I'm comfortable with and I've never seen my Garmin 295, 296 or 496 off by more than 30 feet. Can it happen, yes. Is it a big risk? Not in my estimation. I use VOR and ILS mostly for practice and I use handheld GPS on every flight, no exceptions, since 2000. Just for fun, I've made practice WAAS simulated ILS approaches with the Garmin down to pavement and it's always perfect. You can only get it to do that (lower than 500 AGL) by making an overlay waypoint and assigning a lower altitude to it.kentb said:...
I don't know if it is for real or a OWT, but I have heard of a plane the use using a handheld GPS to make an approach and crashed 2 miles right of coarse on the approach.
Kent
hevansrv7a said:I You can only get it to do that (lower than 500 AGL) by making an overlay waypoint and assigning a lower altitude to it.
I'm doing this from memory; the 496 is not here. Email me if this is not enough or if I get something wrong. I'm glad to help with the understanding that Garmin does not support this and you are PIC!pierre smith said:Could you kindly explain this. I think I know what you're doing...adding another waypoint. I've acquired an as new 496 just today and would like to know.
Pierre
Kent, thanks for your post. I expected that at least one person would say something like this and I don't mind.kentb said:If I understand your directions correctly (and I may not), there could be people telling there 496 to "goto" a point 500 feet below the runway from anywhere they happen to be. This would be regardless of any obstructions between them and that point and also regardless of what would be in front of them when they reached that point.
I know that if you understand where you are and only ask for that kind of guidance when it is correct you will be OK, but people don't always do what they should.![]()
If I understand from you previous post you are using your 496 as a backup to the NAV radio, just to see how well it would do. If so I think that this is fine, but the 496 does not understand (IE will force you) how to fly a correct approach.
Kent
Appreciate the GPS enthusiasm, but lets get real, more accurate than an ILS? ILS and outages? The utility of a single VOR/LOC is still pretty good, or good enough. The price of the equip and the paper plates is a bargain to the IFR GPS with electronic updates. However with VFR GPS on board used as a back-up you can improve IFR safety, no doubt.hevansrv7a said:In my experience, it is more accurate and more dependable than VOR's, ADF's and sometimes ILS's.
Be that as it may, not disagreeing, but its a moot point; I agree its a GREAT back up, its just not legal for IFR and you can bust your a$$ both physically and legally in ways you or I may never have thought of.hevansrv7a said:I don't know either, but I'd trust my '496 more than I would trust my VOR, let alone an ADF.
Your thought process regarding IFR navigation is seriously flawed. GPS is NOT more reliable than ILS and VOR. That's why we are still using them. ILS's have no undetectable failure modes. When they fail, you loose ident and you get a flag. Same for VOR. They have been in continuous use for 50+ years and are not considered to be a source of accidents....
1. Hand held GPS is just as accurate as certified but does not have RAIM. This is fact, not opinion. They are both usually good to about ten feet. They also tell you how accurate they are, should you care to look at that page.Yukon said:Your thought process regarding IFR navigation is seriously flawed. GPS is NOT more reliable than ILS and VOR. That's why we are still using them. ILS's have no undetectable failure modes. When they fail, you loose ident and you get a flag. Same for VOR. They have been in continuous use for 50+ years and are not considered to be a source of accidents.
GPS is operated and or controlled by the military, and is subject to their needs and whims. GPS outages are random and uncontrollable by the civilian community. Even when the military is not screwing with the system, satellites go bad and transmit errant signals, hence the need for complex error-checking signal comparator hardware and software not obtainable in VFR units. I repeat, cheap GPS's are only accurate enough for VFR usage.
The only way SAFE and LEGAL IFR usage of GPS is a certified unit utilizing RAIM and the testing and verification which led to it's approval. You are doing a serious disservice to the experimental community by encouraging our
fellow RV'ers to circumvent the law and the safety it provides. If you can't afford the hardware, do the rest of us a favor and stay out of the clouds.
Yukon said:OK Gil, you searched the internet and found on instance in a foreign country where the ILS was left in "test" by some aussie numbnuts and the monitoring equipmnet was inoperative as well. Does this invalidate my assertion that VFR equipment is unsuitable for IFR operation??? I think not.
You actually are confiming my assertions due to the fact that the ILS system, when flown by competent aviators, can be QC'd by checking vertical descent rate, power requirements and FAF height against the know glideslope angle. Try that with a Garmin 496.
Not to pile on, but what Yukon said. I am very familiar with the ILS test incident, studied it in re-current. Yep stuff happens, it was in test. **az_gila said:Well not quite... that is assigning too high a reliability to any equipment...
The ILS can transmit erronous data...
gil in Tucson - Electronics are good, but not perfect....
hevansrv7a said:Why is this open discussion of facts drawing so much more censure than others?
"If you can't afford the hardware, do the rest of us a favor and stay out of the clouds."Yukon said:Mr Heavensrv7,
Don't mistake disagreement with a lack of civility. Be more careful with your assertions if you want the respect of your fellow aviators.
hevansrv7a said:"If you can't afford the hardware, do the rest of us a favor and stay out of the clouds."
John/Yukon, the rest was fine; this part of what you said was, in my perception, uncivil. Have any of my assertions of fact been refuted yet? If so, I mssed it. I've had much worse said to me, of course. No biggy. I actually like a vigorous disagreement and I think that part adds to the value of the forum for those who read what we say. I just don't think that attacking the author instead of his points helps. I'd welcome the views of others on the civility issue. I'm all talked out on the IFR GPS issue.
H Evan (= H Evan's RV7A)
Yukon said:After spending 2 years on this forum, I am growing weary of hearing how guys are saving money or gaining a technological edge with non-aviation parts and equipment. Car gas, car parts, car motors, car GPS........
RAIM (Receiver Autonomous Integrity Monitoring) and FDE (Fault Detection and Exclusion) are different beasts. Non-WAAS IFR GPSs have RAIM, but not FDE. The RAIM algorithm calculates the position using different sets of the available satellites. E.g., if six satellites are being received, the RAIM algorithm will calculate six different positions, using a different set of five satellites each time. If all satellites are putting out good data, all these positions will be similar. If one satellite is putting out bad data, the positions calculated using different sets of satellites will vary by quite a bit, and the RAIM function will know that there is a problem, but it won't know which satellite is bad. So, it will cause the GPS to stop putting out a position. There is another type of event where there will be enough satellites visible to allow navigation, but not enough satellites to allow the RAIM function to work. In this case the GPS will put out a message like "Unable RAIM", and it will continue to provide navigation info, but it will refuse to switch into approach mode. If the GPS is already in approach mode when the "unable RAIM" event occurs, it will remain in approach mode for a few (five?) minutes.RAIM and FDE - One other BIG difference between the IFR and NON-IFR GPS instrument is a REQUIREMENT that the IFR GPS be able to predict based on flight plan data, the known health status of the observable satellite constellation and the ability of the constellation's "future" geometry (for the duration of the flight!)to provide sufficient navigational performance to complete the flight using the GPS. Yes, it "predicts" the future system performance based on where you are going to take the instrument.
Take a look at section 1-1-19 (d)(1)(a) Global Positioning System (GPS) in the FAA Aeronautical Information Manual. It states:The 496 has integrity monitoring. In fact, you can set the limit for the alarm. SO:
-It has RAIM
-It has up-to-date data base
-Accuracy of mine has been verified
My reading is that it meets the requirement for IFR use in an experimental airplane.
The Garmin 496 has not been approved in accordance with TSO-C129, nor has it been installed in accordance with AC20-138, so it is not legal for IFR navigation.Authorization to conduct any GPS operation under IFR requires that:
(a) GPS navigation equipment used must be approved in accordance with the requirements specified in Technical Standard Order (TSO) TSO-C129, or equivalent, and the installation must be done in accordance with Advisory Circular AC 20-138, Airworthiness Approval of Global Positioning System (GPS) Navigation Equipment for Use as a VFR and IFR Supplemental Navigation System, or Advisory Circular AC 20-130A, Airworthiness Approval of Navigation or Flight Management Systems Integrating Multiple Navigation Sensors, or equivalent.
Steve, I am still trying to download the 496 manual. I am skeptical that it has RAIM but need to read the manual.
I just did a search for RAIM and found nada.
I doubt that your 496 is more accurate than a non-WAAS GNS430..unless you can show me that the 430 uses an unrealistic value for GPS signal accuracy (assumes that neither uses WAAS corrections).
I have made a few homemade approaches (still a VFR approach) to my airport using my 430 in VFR conditions and with a safety pilot. I could do it with my Lowrance Airmap. Would I be legal to do it in IFR conditions? Almost assuredly no.
You can kid yourself that it would be legal and safe to use your 496 that way. And you may get away with it. Or you may be flying an approach when a satellite clock goes bonkers and end up crashing. Today 07:57 AM
Scott, my guess is that the cases are RARE. Frankly this issue is not even on my radar screen should you want to reduce aircraft accidents/fatalities.
Go after the pilot error and poor equipment installation choices on RVs and you can effect a real change.
