If I use the hacksaw method, should I leave the hinges attached and run the hacksaw blade back and forth towards the face of the hinge below?
Should I do this before or after the hinges have been epoxied and riveted?
What sort of a gap between the top/bottom/sides should I leave for paint thickness?
I still need some clarification.
should I be using the blade as a feeler guage? I own feeler guages-- I could use them instead.
OR
should I be using the teeth of the hacksaw blade to create the clearance while the assembly is in place?
