So is it not a good idea to ground a single Pmag setup to forrest of tabs? I have a single PMAG and standard slick mag setup. Thanksemag will send you the required studs and base gasket. Just remind them when you order. Also, if installing dual mags, follow the instructions on grounding, NOT to the forrest of tabs but a common engine point. Also, when timing dual mags, use a tee and time both mags at the same time. It DOES make a difference.
For clarity: The ground being discussed is the electrical ground for the P-mag's internal electronics, and Paul is correct.So is it not a good idea to ground a single Pmag setup to forrest of tabs? I have a single PMAG and standard slick mag setup. Thanks
Correct - Emagair consistently tells everyone to ground the P-Mag to the engine case itself!
