Hey guys, of you have a 430W, you would not need our SkyFYX-EXT GPS source... so 2020 ADS-B Compliance can be had for $999. We include the UAT antenna and wiring harness for that price.
If you do not have a 430W or "Rule Compliant GPS", then you need to get the SkyFYX, SkyFYX-EXT, Dynon2020, GRT Safe-Fly 2020, Garmin20A GPS source or other.
We can work with a host of compliant GPS sources, but it must meet the 2020 rule for a compliant position source. Sorry, no 496, 296, or other portable GPS units. We can pull in the GPS signal from the EFIS, ie GRT using it's Safe-Fly 2020 GPS.
The EchoUAT installation is as simple as Mount- Unit/Ant and GPS if applicable, Connect- Power/Ground/GPS and EFIS serial In/Out if applicable, then program it via our app (iOS or Android) or even via the EFIS.
You can even feed the ADS-B WX/Traffic to an EFIS and your favorite EFB (except the big "G" and "Jepp") at the same time, all others are known to work.
Let me any have any questions.
Shane
