Hi all,
I'll be honest and up front: I don't want to have to read loads of other threads as I'm in a hurry so I'll ask all the questions here and hope to be told "the answer".
Picture the scene...
I've already got an RV6 fitted with an older narrow deck O-320 (160HP). Flies quite nicely, well built, appallingly finished (paint, panel fit-out, instruments etc). She's improving all the time as I work through her. It's much easier to work on something you love than to try to love something you have to work on!
She has a Warnke prop which I think may have the beginnings of a delamination problem at one tip.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any idea if this can be fixed? I'm guessing probably not, and I'm not sure I'd trust it if it was.
I'm considering an aluminium Sensenich prop, ordered from Van's. I know I need to check the bolt size, spacer length (aircraft was built in 1994) and pick the right pitch (80" according to the Van's web site).
Anything else I need to take into account?
What options for a spinner are out there? Do I have to order up, cut and fashion, then paint and fit, a fibreglass spinner from Vans? Are there any 'ready made', maybe metal, options.
Where would I find what length prop bolts I'm likely to require for a selected combination so I can order them up to arrive about the same time?
Hope you don't all take me for a lazy so-and-so. I just want to keep flying with as little interruption as possible. Builders get the chance to think about these things for months or years in advance - I want/need it all in a couple of days!
