olderthandirt
So I did not mark wiring looms when I installed them, now I'm looking at hooking stuff to control panel...does anyone know the color of heat shrink on wiring loom at panel...auto pilot vs..accessories...so I know which plug to putin which socket?? thanks..Dick
No marking on plugs
As far as I can see no marking on plugs...just the different color shrink near plug...I can probably chase wiring back according to color, but it will be difficult...
If you are using the standard avionics install kit with the AV-50000A module, those colors and the different genders of the connectors should allow you to match up with connector location on the AV-50000A (each connector position is color coded).
I am pretty sure this is described in the KAI.
If it's still the same:
O.K. I'm double dumb
yes I did see the colors on the control and would imagine as stated here they match the colors on shrink/Connectors..will look a little closer next time before leaning on you great folks..
