Stockmanreef
Has anybody else purchased a common wire harness from SteinAir or Van's?
I am trying to figure out how to run the stick wire wire bundle. The issue is that the wires are connected up to a flat rectangular port connector. There is no way to run this connector through the 3/4" holes that they are supposed to go through. I assume that the connector has to be removed to run the wire bundle and then put back in place.
I assume that the wire bundle should not be free hanging in the area where the aileron pushrods are.
If there is a common wire harness with all the connectors on (I have not seen Van's wire harness), then why aren't the holes bigger than 3/4? Or have the holes notched like the rest of the holes for the wire harness that runs to the tail cone?
Am I missing something?
Is there another way to fix the wires in place?
ken
ken
