So, I am about to enter the brave new world of fibreglass and the first task that comes my way is bonding in the W-931 spanwise tip rib before riveting it. Vans specifies this in order to avoid the puckering that would result from riveting only.
They also say that the resin should be thickened with flox. Now, searching on "flox" suggests that everybody here is totally familiar with this substance but I am having a real hard time getting hold of it locally. On the other hand, there IS a distributor for the West System. However, West have a range of fillers, none of which are called "Flox" or "Flocked Cotton filler" either.
On the basis of function (strong bond of high density materials), the nearest seems to be 404 High Density Filler (http://westsystem.com/ss/404-high-density-filler/) but on the basis of name, the nearest seems to be the 403 Microfibres (http://westsystem.com/ss/403-microfibers/). Which one do you think I should go for, or are both off the mark?
