Noah
Question-
Are you completing a weight and balance prior to finishing building, and prior to weighing the plane?
I guess what I'm asking is this: When you are building, you need to make decisions about where to locate certain equipment so as not to adversely affect the CG. But the problem is, what is your starting point? Does Vans or anybody else have an empty weight and CG of a stock 7A with no instruments, engine, or prop (essentially airframe only), so that you can take it from there and add what you want for options?
I've heard people say that the 7A is tail heavy, and putting a heavy prop on it helps in this regard. But this is qualitative. As far as I can tell, you really don't know how much of an effect you've had on things until you get the plane complete (or at least on the gear so that you can establish the weight and CG). It seems to me, this is too late to "discover" what you have, and be able to change things if necessary. I'd really rather start with a basic "stock" airframe W&B and then add all of my equipment from there. When I'm done, hopefully the spreadsheet calculations would be reasonably close to the as-weighed values.
I'm familiar with Checkoway's database of W&B for completed planes, which is good, but you still have to back out what everybody in there has for equipment and you still don't know where things are located (ELT and strobe power supply, for examples). This is more of a "top down" number, and so has somewhat limited utility as compared to a "bottoms up" W&B.
So does anybody start a weight and balance spreadsheet early, during the build, as a tool to help make informed decisions about equipment location and ensuring your empty weight isn't ridiculous??
