I just purchased an RV-4, and am loving it. I had a question about W&B though. The info the plane came with listed the empty weight at 1014lb, with an empty cg of 66” (datum 60” fwd of LE). First, the weight seems high for the plane. It’s an O-320 fixed pitch wood prop with VFR only instruments and a short gear. Second, it seems like no matter what I do, the CG is extremely far forward. Even with baggage or a passenger or full fuel, it’s pretty close to the forward limit. Is this normal? I asked the seller and he doesn’t know when the weights were taken. Is it a good idea to reweigh the plane? And can I do that myself?
