Pat Stewart
Just curious if anyone would share their empty weight CG as well as actual weights at each location.
Pat
Pat
Maybe double check that you are level laterally & yeah, swap scales.I have no idea why the left main is so much heavier than the right main.
My aircraft came out like this:
Right Main 613
Left Main 640
Nose 366
Total = 1619 for a CG of 107.58
I will probably weigh it again next weekend and swap the left and right scales.
Pat
Maybe some of the bigger boys could post "the weight of their friends -10"![]()
Mine weighs 129 Stone, but I blame it all on the paint![]()
I came in at a portly 1724.1 and 107.957
Fully painted, full interior, A/C, and soundproofing.
2 blade Hartzell, full interior, dual batt (LiFePo), dual alternator, dual AHARS, IFR G3X panel.
1645lbs @ 105.78in
