dmattmul
I'm going to pick up my RV-14 from paint this Friday. I've checked the W&B with maximum load in the luggage compartment and the numbers worked fine. My airframe because of the composite prop and lighter batteries tends to come out a little aft heavy but still ok. (I have a IO390 which helps) This trip I will have 50#'s in the baggage area not the 100 lbs. with max baggage. I'd like to run some numbers before I pick it up. Can anyone give me a ballpark calculation of the increase in W&B by load point (Tires) I should, see?
